>> 网页设计交流,相互学习,共同进步……
泥客论坛(二十年前的回忆)泥客技术☆网页制作☆ → Asp无组件文件上传的实例
您是本帖的第 5837 个阅读者
Asp无组件文件上传的实例
oneeo
文章:1
注册:2007年6月21日
 点击这里发送电子邮件给oneeo
Asp无组件文件上传的实例
Asp无组件文件上传的实例
1.库文件(upload.inc.asp)
Dim oUpFileStream
Class UpFile_Class
Dim Form,File,Version,Err
Private Sub Class_Initialize
Version = "无组件上传类 Version V1.0"
Err = -1
End Sub
Private Sub Class_Terminate
'清除变量及对像
If Err < 0 Then
Form.RemoveAll
Set Form = Nothing
File.RemoveAll
Set File = Nothing
oUpFileStream.Close
Set oUpFileStream = Nothing
End If
End Sub
Public Sub GetData (RetSize)
'定义变量
Dim RequestBinDate,sSpace,bCrLf,sInfo,iInfoStart,iInfoEnd,tStream,iStart,oFileInfo
Dim iFileSize,sFilePath,sFileType,sFormValue,sFileName
Dim iFindStart,iFindEnd
Dim iFormStart,iFormEnd,sFormName
'代码开始
If Request.TotalBytes < 1 Then
Err = 1
Exit Sub
End If
If RetSize > 0 Then
If Request.TotalBytes > RetSize Then
Err = 2
Exit Sub
End If
End If
Set Form = Server.CreateObject ("Scripting.Dictionary")
Form.CompareMode = 1
Set File = Server.CreateObject ("Scripting.Dictionary")
File.CompareMode = 1
Set tStream = Server.CreateObject ("ADODB.Stream")
Set oUpFileStream = Server.CreateObject ("ADODB.Stream")
oUpFileStream.Type = 1
oUpFileStream.Mode = 3
oUpFileStream.Open
oUpFileStream.Write Request.BinaryRead (Request.TotalBytes)
oUpFileStream.Position = 0
RequestBinDate = oUpFileStream.Read
iFormEnd = oUpFileStream.Size
bCrLf = ChrB (13) & ChrB (10)
'取得每个项目之间的分隔符
sSpace = MidB (RequestBinDate,1, InStrB (1,RequestBinDate,bCrLf)-1)
iStart = LenB (sSpace)
iFormStart = iStart+2
'分解项目
Do
iInfoEnd = InStrB (iFormStart,RequestBinDate,bCrLf & bCrLf)+3
tStream.Type = 1
tStream.Mode = 3
tStream.Open
oUpFileStream.Position = iFormStart
oUpFileStream.CopyTo tStream,iInfoEnd-iFormStart
tStream.Position = 0
tStream.Type = 2
tStream.CharSet = "gb2312"
sInfo = tStream.ReadText
'取得表单项目名称
iFormStart = InStrB (iInfoEnd,RequestBinDate,sSpace)-1
iFindStart = InStr (22,sInfo,"name=""",1)+6
iFindEnd = InStr (iFindStart,sInfo,"""",1)
sFormName = Mid (sinfo,iFindStart,iFindEnd-iFindStart)
'如果是文件
If InStr (45,sInfo,"filename=""",1) > 0 Then
Set oFileInfo = new FileInfo_Class
'取得文件属性
iFindStart = InStr (iFindEnd,sInfo,"filename=""",1)+10
sFileName = Mid (sinfo,iFindStart,iFindEnd-iFindStart)
oFileInfo.FileName = Mid (sFileName,InStrRev (sFileName, "\")+1)
oFileInfo.FilePath = Left (sFileName,InStrRev (sFileName, "\")+1)
oFileInfo.FileExt = Mid (sFileName,InStrRev (sFileName, ".")+1)
iFindStart = InStr (iFindEnd,sInfo,"Content-Type: ",1)+14
iFindEnd = InStr (iFindStart,sInfo,vbCr)
oFileInfo.FileType = Mid (sinfo,iFindStart,iFindEnd-iFindStart)
oFileInfo.FileStart = iInfoEnd
oFileInfo.FileSize = iFormStart -iInfoEnd -2
oFileInfo.FormName = sFormName
file.add sFormName,oFileInfo
else
'如果是表单项目
tStream.Close
tStream.Type = 1
tStream.Mode = 3
tStream.Open
oUpFileStream.Position = iInfoEnd
oUpFileStream.CopyTo tStream,iFormStart-iInfoEnd-2
tStream.Type = 2
sFormValue = tStream.ReadText
If Form.Exists (sFormName) Then
Form (sFormName) = Form (sFormName) & ", " & sFormValue
else
form.Add sFormName,sFormValue
End If
End If
tStream.Close
iFormStart = iFormStart+iStart+2
'如果到文件尾了就退出
Loop Until (iFormStart+2) = iFormEnd
RequestBinDate = ""
Set tStream = Nothing
End Sub
End Class
'文件属性类
Class FileInfo_Class
Dim FormName,FileName,FilePath,FileSize,FileType,FileStart,FileExt
'保存文件方法
Public Function SaveToFile (Path)
On Error Resume Next
Dim oFileStream
Set oFileStream = CreateObject ("ADODB.Stream")
oFileStream.Type = 1
oFileStream.Mode = 3
oFileStream.Open
oUpFileStream.Position = FileStart
oUpFileStream.CopyTo oFileStream,FileSize
oFileStream.SaveToFile Path,2
oFileStream.Close
Set oFileStream = Nothing
if Err.Number<>0 then
SaveToFile=err.number&"**"&Err.descripton
else
SaveToFile="ok"
end if
End Function
'取得文件数据
Public Function FileDate
FileDate = oUpFileStream.Read (FileSize)
End Function
End Class
2.处理用户提交后的页面(upload.asp)
<!--#include file="upload.inc.asp"-->
<html>
<head>
<title>文件上传</title>
</head>
<body topmargin="0" leftmargin="0">
<table width=100% border=0 cellspacing="0" cellpadding="0"><tr><td class=tablebody1 width=100% height=100% >
dim upload,file,formName,formPath,filename,fileExt
dim ranNum
call UpFile()
'===========无组件上传(upload_0)====================
sub UpFile()
set upload=new UpFile_Class '建立上传对象
upload.GetData (500*1024) '取得上传数据,此处即为500 K
if upload.err > 0 then
select case upload.err
case 1
Response.Write "请先选择你要上传的文件 [ <a href=# onclick=history.go(-1)>重新上传</a> ]"
case 2
Response.Write "图片大小超过了限制 500 K [ <a href=# onclick=history.go(-1)>重新上传</a> ]"
end select
exit sub
else
formPath=upload.form("filepath") '文件保存目录,此目录必须为程序可读写
if formPath="" then
formPath="rwdata/"
end if
'在目录后加(/)
if right(formPath,1)<>"/" then
formPath=formPath&"/"
end if
for each formName in upload.file '列出所有上传了的文件
set file=upload.file(formName) '生成一个文件对象
if file.filesize<100 then
response.write "请先选择你要上传的图片 [ <a href=# onclick=history.go(-1)>重新上传</a> ]"
response.end
end if
fileExt=lcase(file.FileExt)
if CheckFileExt(fileEXT)=false then
response.write "文件格式不正确 [ <a href=# onclick=history.go(-1)>重新上传</a> ]"
response.end
end if
'randomize
ranNum=int(90000*rnd)+10000
filename=formPath&year(now)&month(now)&day(now)&hour(now)&minute(now)&second(now)&ranNum&"."&fileExt
if file.FileSize>0 then '如果 FileSize > 0 说明有文件数据
result=file.SaveToFile(Server.mappath(filename)) '保存文件
if result="ok" then
response.write formName&" upload OK, had saved to "&filename&"<br>"
else
response.write formName&" upload Fail,"&result&"<br>"
end if
end if
set file=nothing
next
set upload=nothing
end if
end sub
'判断文件类型是否合格
Private Function CheckFileExt (fileEXT)
dim Forumupload
Forumupload="gif,jpg,bmp,jpeg"
Forumupload=split(Forumupload,",")
for i=0 to ubound(Forumupload)
if lcase(fileEXT)=lcase(trim(Forumupload(i))) then
CheckFileExt=true
exit Function
else
CheckFileExt=false
end if
next
End Function
</td></tr></table>
</body>
</html>
3.HTML 表单(upload.html)
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=gb2312">
<title>asp 无组件上传</title>
</head>
<body>
请选择要上传的文件
<form action="upfile.asp" method="post" enctype="multipart/form-data" name="form1">
<input type="file" name="file">
<!--<br>
<br>
<br>-->
<input type="submit" name="Submit" value="提交">
</form>
</body>
</html>
2007/6/21 16:20:36
页面执行时间 00.04688 秒, 4 次数据查询
